TwinTurbo.NET: Nissan 300ZX forum - Re: Why would you pull the crank pulley to do the water pump?
Subject Re: Why would you pull the crank pulley to do the water pump?
Posted by Aldrand on June 03, 2012 at 2:46 PM
  This message has been viewed 161 times.
In Reply To Why would you pull the crank pulley to do the water pump? posted by Draker (Eugene, OR) on June 03, 2012 at 01:09 PM
Message In order to get to the bottom three bolts of the water pump you have to take the bottom timing cover off which is being blocked on by the crank pulley.
